Folders for routes and logs
Mike Stueber
Mike Stueber
Posts: 54, Visits: 196
Hallo SkyDemon team,
I'm using SkyDemon over three years.
The number of routes and logs increases.
Would it be possible to give to the users the possibility to create folders?
With folders one would have more clarity.
Kind regards,
Mike‌‌‌‌‌‌‌
Not easily, no. Although if you're using SkyDemon on a PC it's fairly trivial to create folders and manage your route files that way.
iOS and Android are less geared towards users having direct control over the file system.
Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)
Posts: 616, Visits: 30K
Could we not have folders in the Cloud storage?
jfw
jfw
Posts: 134, Visits: 485
grahamb - 5/15/2017 7:32:28 PM
It is true that organising the routes only based on the name is becomming complicated and that folders would greatly help.
derWessi
derWessi
Posts: 63, Visits: 157
+1
SemperFi - 5/21/2017 9:47:36 AM
Why not simply let the filename start by year-month-day, so the sorted list is automatically organized as loglist?
Because I like to organise them by IFR/VFR and airport of departure. It doesn't matter what sequence they are in, it's a pain finding the one you want when you have several hundred routes saved.
Now that the next release merges locallly saved and cloud saved routes by default, can I repeat my plea for a better way of organising them?
I name my routes following a consistent standard, but it’s still tiresome scrolling through them all to find one. Folders would help a lot.
We currently allow alphabetic and date sorting. Could you perhaps elaborate on how many routes you have, the nature of why there are so many and your pattern of accessing them? Many thanks.
I have approx 300 routes saved. I have habitually named virtually all of them in the format ‘XXX DEP-DEST [via AAAA] [Other Qualifier] where:
XXX is VFR or IFR.
DEP is Airport of departure, always a meaningful name except when it’s EGCW, my home base.
DEST is Destination airport, as above
AAA optionally would specify a particular route
The Other Qualifier may be used to annotate any other discriminator.
Routes extend to, from and within a number of Western European countries; some go back nearly as long as SkyDemon has existed, I’ll often plan a long multi leg trip some time in advance, playng with a number of options, whilst researching accommodation options for the overnight stops. If IFR it may take several iterations for each leg back and forth with EuroFPL or Autorouter to get an efficient route validated. I’ll keep routes, as though things may change, a route that has worked before is always the best starting point for flying to the same destination again.
I haven’t fully thought through yet how I would use folders, but the ability to save a basket of routes for a specific trip would be useful; as would grouping them by country or other area.
plume_tray
plume_tray
Posts: 116, Visits: 434
Would a search box help within the Open dialog box? Also, the ability to rename and/or duplicate routes too.
