Visits: 3.5K
Dirk,
You can find this information when you tap and hold on the chart within such a TMZ and then tap the TMZ in the 'What's here" menu.
By the way, setting this squawk and selecting this frequency is not mandatory. You only have to activate mode S within these TMZs. Only when you select the special squawk you also have to change to that special frequency. By selecting this squawk you indicate that you listen to that frequency, hence 'listening squawk'. Well proven for a long time in the UK.
Eric
