By dirktg - 3/31/2017 5:29:59 PM
Hello Skydemon team, I'm wondering where I can find information about the new German TMZ situation valid from Mar, 30th 2017. Like mentioned in this document, you have to set a transponder code an also listen to a defined frequence when flying in german TMZ. My chart updatelevel is current (PC-Version, valid to Apr. 27th).
A I blind or are the charts missing this information.
Thanks in advance for your answer and brgds Dirk
By dirktg - 4/2/2017 6:47:49 PM
+xDirk,You can find this information when you tap and hold on the chart within such a TMZ and then tap the TMZ in the 'What's here" menu.By the way, setting this squawk and selecting this frequency is not mandatory. You only have to activate mode S within these TMZs. Only when you select the special squawk you also have to change to that special frequency. By selecting this squawk you indicate that you listen to that frequency, hence 'listening squawk'. Well proven for a long time in the UK.Eric Thank for your help! Yes, you are right, information is available now. I expected the information directly in the chart, as shown in the NfL letter. brgds Dirk
