Resetting leg altitude to route level in planning mode
FoxAviation
F
Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)Too Much Forum (193 reputation)
Posts: 2, Visits: 0
# Motivation #
I often use SkyDemon in environments, where there is not just a single cuise altitude necessary, but multiple level changes necessary during one single flight. Depending on i.e. weather changes (cloud base, ...) , I find myself a lot changing altitudes in the planning window. However, it seems to me quite difficult to quickly reset a leg to route level. This surely is not a great deal, if it's just a single leg. But resetting multiple legs can be a rather time-consuming process.
# Suggestion #
I suggest to add a shortcut to reset an altitude to route level by selecting the leg in the Virtual Radar, while holding down i.e. SHIFT, ALT or any not otherwise allocated modifier. Such a "<modifier> + click" shortcut would help a lot, be easy to implement and would not lead to many accidental uses in my opinion.
With kind regards‌
I appreciate the requirement, which (as I understand it) is a quicker way to restore a leg to route level than simply dragging the leg until it reaches that level.
Unfortunately the suggested solution of holding down a key will not work on tablets, therefore it wouldn't help a large percentage of users. It is also not very discoverable.
FoxAviation
F
Posts: 2, Visits: 0
@SkyDemon Team
I totally get your poin‌t. But maybe there is a different solution for touch-based devices, that facilitates this process as well. My point is not primarily on the invention of the shortcut (which could be added anyway), but on the simplification of the resetting.‌‌‌‌
Thanks for your help
