Resetting leg altitude to route level in planning mode
http://forums.skydemon.aero/Topic21076.aspx
By FoxAviation - 12/18/2016 6:59:49 PM
# Motivation #
I often use SkyDemon in environments, where there is not just a single cuise altitude necessary, but multiple level changes necessary during one single flight. Depending on i.e. weather changes (cloud base, ...) , I find myself a lot changing altitudes in the planning window. However, it seems to me quite difficult to quickly reset a leg to route level. This surely is not a great deal, if it's just a single leg. But resetting multiple legs can be a rather time-consuming process.
# Suggestion #
I suggest to add a shortcut to reset an altitude to route level by selecting the leg in the Virtual Radar, while holding down i.e. SHIFT, ALT or any not otherwise allocated modifier. Such a "<modifier> + click" shortcut would help a lot, be easy to implement and would not lead to many accidental uses in my opinion.
With kind regards‌
By FoxAviation - 12/19/2016 4:24:04 PM
@SkyDemon Team
I totally get your poin‌t. But maybe there is a different solution for touch-based devices, that facilitates this process as well. My point is not primarily on the invention of the shortcut (which could be added anyway), but on the simplification of the resetting.‌‌‌‌
Thanks for your help
