Posts: 8.1K,
Visits: 9.3K
They've made it worse, it would seem. They are now attempting to describe two geographical objects (an area and a route) in one NOTAM which is fraught with the potential for error. Graphical depiction of NOTAM is never perfect because the NOTAM system wasn't designed in that way, but SkyDemon will normally get it right as long as the source data is good. A polygon is generally fine; a line is generally fine; mixing the two is unlikely to work.
