By mschmoelzer - 9/14/2016 6:49:57 PM
I noticed that sometimes the area highlighting feature of SkyDemon generates self-intersecting polygons. For example, this NOTAM:
D) DAILY 1600 - 2130 E) NIGHT VFR TRAINING FLIGHTS (NVG OPS) BURGENLAND AREA OBERWART: 473120N 0161150E 472750N 0163820E 470250N 0160720E 470050N 0162850E START HELIPORT OEAMTC OBERWART LODO PARTICIPATING HELICOPTER: OEXEK OR OEXEQ (EC 135) MONITORING 134,675MHZ F) GND G)2500FT AGL
is displayed as a self-intersecting polygon - see the images in this gallery: http://imgur.com/a/Sx3i8
I assume this happens due to the order of the vertices (coordinates) in the NOTAM - I think this feature would look much nicer if there was some algorithm involved which can detect this condition and re-order the vertices
Kind regards Martin
By Tim Dawson - 9/16/2016 2:27:36 PM
They've made it worse, it would seem. They are now attempting to describe two geographical objects (an area and a route) in one NOTAM which is fraught with the potential for error. Graphical depiction of NOTAM is never perfect because the NOTAM system wasn't designed in that way, but SkyDemon will normally get it right as long as the source data is good. A polygon is generally fine; a line is generally fine; mixing the two is unlikely to work.
