Visits: 494
Hi Team,
It looks like there is a synchronisation issue with Aircraft Library in the Cloud. Whilst I can select one aircraft among several on the SD iPad version, the PC version shows an empty folder despite several attempts to save to Cloud (from the iPad) and Load from Cloud from the PC. This used to work fine in earlier versions. Is anyone else seeing the same behavior ?
Thanks, Jose Running SD on: PC 3.6.3.0 (Windows 7 Pro) iPad mini4 3.6.3.47 (iOS 9.3.5)
