Aircraft Libraries synchronisation issue
http://forums.skydemon.aero/Topic19944.aspx
By Gyro79 - 9/1/2016 7:18:52 AM
Hi Team,
It looks like there is a synchronisation issue with Aircraft Library in the Cloud.
Whilst I can select one aircraft among several on the SD iPad version, the PC version shows an empty folder despite several attempts to save to Cloud (from the iPad) and Load from Cloud from the PC.
This used to work fine in earlier versions.
Is anyone else seeing the same behavior ?
Thanks,
Jose
Running SD on:
PC 3.6.3.0 (Windows 7 Pro)
iPad mini4 3.6.3.47 (iOS 9.3.5)
By Gyro79 - 9/1/2016 4:49:44 PM
Tim Dawson - 9/1/2016 4:05:49 PM
No. Are you positive both devices are logged in to the same SkyDemon account?
A logout and login session has cleared the issue.
Thanks !
