Aircraft profiles
dbotop
d
Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)Too Much Forum (206 reputation)
Posts: 1, Visits: 0
Hallo,
I checked the forum allready for problems with entering aircraft profiles, but could not find a solution. I'm trying to make a polygon for my Lancair 360 Mk1, but whatever I input, the profile will return garbage.
Basically the numbers should (roughly) be:
153,532, 153,600, 160,810, 168,810, 168,532 (arm, weight)
After entering these numbers the profile keeps returning the numbers: 15600,00; 8100,0. Adding either one or two decimals after the numbers does not change this weird behaviour. What could be going wrong?
Appreciation your help,
Dave
PH-DBO
P.S. Im using the 30 days trial version if that matters.
efrenken
efrenken
Posts: 265, Visits: 3.5K
From user guide (page 29):
Depending on your regional settings, you may need to use a comma as a decimal separator, and a semicolon to separate the x and y values: 83,00;550,00 83,00;890,00 87,00;1060,00 etc.
Eric
Edited 8/21/2016 9:16:26 AM by efrenken
