		| By dbotop - 8/13/2016 1:54:28 PM
 Hallo,
 I checked the forum allready for problems with entering aircraft profiles, but could not find a solution. I'm trying to make a polygon for my Lancair 360 Mk1, but whatever I input, the profile will return garbage.
 Basically the numbers should (roughly) be:
 153,532, 153,600, 160,810, 168,810, 168,532 (arm, weight)
 After entering these numbers the profile keeps returning the numbers: 15600,00; 8100,0. Adding either one or two decimals after the numbers does not change this weird behaviour. What could be going wrong?
 Appreciation your help,
 Dave
 PH-DBO
 P.S. Im using the 30 days trial version if that matters.
		| By efrenken - 8/21/2016 9:11:56 AM
 From user guide (page 29):
 Depending on your regional settings, you may need to use a comma as a decimal separator, and a semicolon to separate the x and y values: 83,00;550,00 83,00;890,00 87,00;1060,00 etc.
 Eric
