Slovenian Entry/Exit Points - SD FPL's invalid
AndreasMueller
A
Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)Too Much Forum (125 reputation)
Posts: 1, Visits: 0
It helps to insert a IFR waypoint which is near your requested entrypoint.
‌Andreas Mueller
Easy Cruising
Easy Cruising
Posts: 50, Visits: 39
Just as a follow-up to this one: yesterday I made a vfr flight from ostrava to portoroz in Slovenia. I entered Slovenia via RADLY point and followed the route VFR1 to Portoroz. I set my SD FPL waypoints at all the visual reporting points like TREBNJE but the SD FPL contained only RADLY VFR1 (names not coordinates) for the Slovenian portion. I manually entered an RMK to indicate entry to Slovenia via RADLY also. This FPL was accepted and I flew it with no issues. It's not clear to me why SD puts in VFR1 to represent all the other points but it did work.
Easy Cruising - 8/2/2017 8:37:31 AM
When you are following an official VFR route you specify the point atwhich you join the route followed by the route name and the point at which you exit. So what SD generated is perfectly OK and ought to work, which it apparently did.
-- Chris.‌‌
