Slovenian Entry/Exit Points - SD FPL's invalid
Easy Cruising
Easy Cruising
Posts: 50, Visits: 39
I noticed that SD generated FPL's through Slovenian airspace will never be accepted because SD uses 'coordinates' rather than official entry/exit points. (I had one unaltered SD generated plan rejected recently for this reason). Slovenian AIP:
REF AIP SLOVENIA ENR 1.10 PARA 1.3. B. SPECIALARANGEMENTS FOR IFR AND VFR FLIGHTS (ICAO NOTIFICATION OF DIFFERENCE) FLIGHTPLANS WITH FLIGHT ROUTES CROSSING FIR LJLA BOUNDARY OR VOLUMES OF CONTROLAIRSPACE SHALL INCLUDE OFFICIALLY PUBLISHED ENTRY/EXIT REPORTING POINTS.COORDINATES OR ANY OTHER NAMES ARE NOT ALLOWED THEREFORE SUCH FPL WILL BEREJECTED.
.. not sure what we can do about that in SD. I guess we have to remember to make manual changes to the plans.
Easy Cruising - 8/2/2017 8:37:31 AM
Just as a follow-up to this one: yesterday I made a vfr flight from ostrava to portoroz in Slovenia. I entered Slovenia via RADLY point and followed the route VFR1 to Portoroz. I set my SD FPL waypoints at all the visual reporting points like TREBNJE but the SD FPL contained only RADLY VFR1 (names not coordinates) for the Slovenian portion. I manually entered an RMK to indicate entry to Slovenia via RADLY also. This FPL was accepted and I flew it with no issues. It's not clear to me why SD puts in VFR1 to represent all the other points but it did work.
When you are following an official VFR route you specify the point atwhich you join the route followed by the route name and the point at which you exit. So what SD generated is perfectly OK and ought to work, which it apparently did.
-- Chris.‌‌
Easy Cruising - 8/4/2016 4:35:57 PM
Tim Dawson - 8/5/2016 10:56:15 AM
Easy Cruising - 8/5/2016 7:20:16 PM
damirf - 10/5/2016 2:56:58 PM
Tim Dawson - 10/5/2016 3:07:04 PM
damirf - 10/5/2016 4:27:41 PM
Tim Dawson - 10/5/2016 4:30:25 PM
tnowak - 10/7/2016 9:45:02 AM
Easy Cruising - 10/9/2016 7:46:38 AM
ckurz7000 - 10/9/2016 7:44:52 PM
Tim Dawson - 10/10/2016 10:21:07 AM
ckurz7000 - 10/11/2016 3:34:23 PM
Easy Cruising - 10/12/2016 5:57:46 AM
Tim Dawson - 10/11/2016 4:32:55 PM
ckurz7000 - 10/11/2016 8:47:12 PM
Tim Dawson - 10/12/2016 8:09:54 AM
rjmusto - 12/30/2016 7:33:45 PM
Easy Cruising - 1/1/2017 12:59:59 PM
rjmusto - 1/1/2017 6:06:49 PM
Tim Dawson - 1/3/2017 11:34:30 AM
ckurz7000 - 8/2/2017 2:03:27 PM
AndreasMueller - 2/23/2017 6:10:56 AM
