Any way to add mulitple landings on one route?
CptPendle
CptPendle
Posts: 10, Visits: 17
Greetings,
I am a new user so please forgive me if this is something obvious that I have missed.
I have attached a plan as an example. It is a rough plan fro my forthcoming Qualifying Cross Country which involves a triangular route with 2 away landings and then final landing back at home.
The normal thing is obviously to do a separate plan and plog for each leg of the route that involves a landing. This would result in 3 plans 9and 3 separate plogs etc.)
However. It would be great if, for chart purposes for example, I could use the plan as it is and simply add landings at the two other airports within the same plan - so I can see all charts / plates etc. when printing.
So my question is - is there any way to do this? I realise that it is not the normal thing to do. Timings etc. would be messed up as landing will interrupt timing. But I feel it may be useful.
Thanks.
Phil Pendlebury
http://www.pendlebury.biz/
QCX.zip (687 views, 1.00 KB)
You're correct in your conclusion that SkyDemon doesn't really support this at the moment, and that the "correct" thing to do would be to produce three different routes and PLOGs.
We do plan to add multiple sector support to SkyDemon in a future version, probably this year, but it's still quite tentative.
CptPendle
CptPendle
Once again, as suspected, and thanks for the prompt reply - saved me spending hours trying to do something that doesn't exist. Smile
Phil Pendlebury
chinesespaceman
chinesespaceman
Posts: 19, Visits: 61
on this subject, i can't see a way to add multiple diversion airfields on a long xc.
For example I might want to designate 3 airfields along a given route in case of a need to divert at any point. However when I apply a diversion it only tags to the designated landing airfield at the end of the plog.
Any comments on this appreciated
Gavin
CptPendle
CptPendle
Hi Gavin,
Yup I also came across this. I think it is something that will be added hopefully.
Phil Pendlebury
chinesespaceman
chinesespaceman
Any comment / feedback on the en-route diversions and multiple landings?
Gavin
My last comment above still stands:
