SkyDemon Flight Planning
Any way to add mulitple landings on one route?
CptPendle
CptPendle
posted 2/10/2011 11:20:12 AM
Visits: 17
Greetings,
I am a new user so please forgive me if this is something obvious that I have missed.
I have attached a plan as an example. It is a rough plan fro my forthcoming Qualifying Cross Country which involves a triangular route with 2 away landings and then final landing back at home.
The normal thing is obviously to do a separate plan and plog for each leg of the route that involves a landing. This would result in 3 plans 9and 3 separate plogs etc.)
However. It would be great if, for chart purposes for example, I could use the plan as it is and simply add landings at the two other airports within the same plan - so I can see all charts / plates etc. when printing.
So my question is - is there any way to do this? I realise that it is not the normal thing to do. Timings etc. would be messed up as landing will interrupt timing. But I feel it may be useful.
Thanks.
Phil Pendlebury
http://www.pendlebury.biz/
QCX.zip
688 views,
1.00 KB
CptPendle
You're correct in your conclusion that SkyDemon doesn't really support...
2/10/2011 12:57:48 PM
Once again, as suspected, and thanks for the prompt reply - saved me...
CptPendle
2/10/2011 2:18:07 PM
on this subject, i can't see a way to add multiple diversion airfields...
chinesespaceman
3/6/2011 11:04:11 PM
Hi Gavin,
Yup I also came across this. I think it is...
CptPendle
3/7/2011 9:21:44 AM
Hi Tim, Any comment / feedback on the en-route diversions and...
chinesespaceman
3/17/2011 10:45:16 PM
My last comment above still stands: We do plan to add multiple sector...
3/21/2011 5:56:18 PM
