SkyDemon on Linux
baffled
baffled
Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)Too Much Forum (468 reputation)
Posts: 4, Visits: 17
Hi - Having the same problem with V3.12.12. I emailed the lovely support team at SkyDemon and they sent me a zipped copy of the version 3.12.11 setup for windows which works just fine under wine. Not  a permanent solution by any means, but it's better than nothing until a work-around is produced for the latest version.
Not quite sure why there isn't a repository of older versions, but I was genuinely surprised they didn't just say 'we don't support linux' and leave it at that. Thanks to Hannah Hart.
Cheers
B
We don't support Linux, but have no problem with people setting up an emulation environment to run SkyDemon under such conditions.
b3nn0
b
Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)Too Much Forum (518 reputation)
Posts: 42, Visits: 3.4K
Latest version (3.13.0.0) is working in wine again. Thanks!
EDIT: Note however, that I did try to install a bunch of things to get the previous version running (without success). Not sure if it would also work without this.
Edited 12/9/2019 9:06:54 AM by b3nn0
Joachim Zach
J
Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)Too Much Forum (182 reputation)
Posts: 10, Visits: 5
Thank you for the message. Works for me as well.
Pischel
P
Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)Junior Member (15 reputation)
Posts: 1, Visits: 0
Dario70 - 4/3/2016 9:37:22 AM
Hello all,
For all Linux user that want use Skydemon on linux :
http://www.bytebang.at/Blog/Running+SkyDemon+under+Linux+with+wine
Link
Work 100% on Arch.
Happy landings.
Hi All,
I tried to install Skydemon on Ubuntu using wine. Finally I gave up on wine.
Today I decided to use a virtual machine on top of Ubuntu 21.10. The virtual machine software is from Oracle and called VirtualBox. For private use, this software is licensed without fees. Within VirtualBox, I installed Windows 7. Within Windows 7 I installed Skydemon. It works just fine.
All this was done in less than an hour. I recommend to follow this video: https://www.youtube.com/watch?v=qc3tatME9k4
Worked for me.
Best regards, Jochen
Erdie
E
Posts: 3, Visits: 0
I recently got it running with wine under Gentoo Linux. For setting it up I used the tool Q4wine, with actually does all the winetricks stuff and furthermore creating a new enviroment. Make sure that is is 32bit! I run the dotnet 4,72 winetricks scripts and it finally worked. There is one feature missing: If you move the curser over certain airspaces, it does not show up a tooltip like window which explains the airspace structure at that point. This is not a big issue because you can see it on the virtual radar as well or you just need to check the bounderies on the map.
But I did not discover any other flaws, it is completly useable. If you stress the application window: Resize, fullscreen, toggle window mode and something like that a crash might happen. I got it twice in the last weeks but when do normal planning stuff it looks stable. I will keep on running it in wine because using a VM for it is just a overkill and the wine version is much faster. It is incredible fast compared to Virtualbox. Just ask if you have futher questions.
Nik
N
Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)Too Much Forum (109 reputation)
Posts: 16, Visits: 0
Erdie - 2/26/2022 3:39:06 PM
I like it on linux (mint) too. But I'm struggling with linux basics.
How do you add the dotnet 4.72 exactly? I found it in the Menu "Settings" -> Winetricks -> dlls. I was able to click and install it. But when I start the skydemonsetup.exe in the explorer, I get the error "SkyDemon requires Microsoft .NET Framework 4.7.2"
What is missing?
b3nn0
b
If anyone is interested: I created an installer-script for Lutris, which will install all needed dependencies. It will also configure wine to use a virtual desktop, otherwise the mouse-hover popups will not work. If you don't like it, feel free to disable that.
Let me know if something isn't working, and I'll try to add it.
Lutris script:
game_slug: skydemon
version: Installer
slug: skydemon-installer
runner: wine
script:
files:
- webview2: https://msedge.sf.dl.delivery.mp.microsoft.com/filestreamingservice/files/7b6f380d-d407-4145-b81d-af58f4c19765/MicrosoftEdgeWebview2Setup.exe
- installer: "N/A:Select SkyDemon Setup File"
game:
exe: drive_c/Program Files/SkyDemon/SkyDemon.exe
prefix: $GAMEDIR
arch: win32
working_dir: $GAMEDIR
installer:
- task:
arch: win32
description: Setting up wine prefix
prefix: $GAMEDIR
- task:
app: dotnet472
description: Installing .NET Framework
prefix: $GAMEDIR
- task:
app: corefonts
arch: win32
description: Installing additional fonts for proper font display
prefix: $GAMEDIR
- task:
app: gdiplus
arch: win32
description: Installing GDIPlus
prefix: $GAMEDIR
- task:
app: gdiplus_winxp
arch: win32
prefix: $GAMEDIR
- task:
executable: webview2
prefix: $GAMEDIR
- task:
executable: installer
prefix: $GAMEDIR
- task:
arch: win32
prefix: $GAMEDIR
wine:
dxvk: true
esync: true
Desktop: true
WineDesktop: 1920x1080
EDIT: Also added it to the Lutris web site, still awaiting approval though.
Edited 5/22/2023 12:01:19 PM by b3nn0
Belga
B
Posts: 2, Visits: 0
Hi b3nn0,
hope you're still hanging around. I'm pretty new to Linux (Fedora 43 distro) and tried to install SkyDemon via your Lutris installation script.
The install process itself seemed to work well (except I was asked a gazillion times if I want to install Dotnet 4.8.1), but I ran into two problems after the installation was finished.
1.) SkyDemon.exe could not be found. Reason: path is set to "/home/[username]/Spiele/skydemon/drive_c/Program Files/SkyDemon/SkyDemon.exe", but my version of SkyDemon (I installed V4.2.3) installs the exe into "/home/stephan/Spiele/skydemon/drive_c/Program Files (x86)/SkyDemon/". I set the new path manually in the SkyDemon settings under Lutris.
2.) After solving problem 1, I was greeted with "Proton is not compatible with 32-bit prefixes."
I'm wondering if an Linux, Wine or Proton update messed up your script or if I'm just making a mistake during the installation process.
Here is the detailed log:
Traceback (most recent call last):
File "/usr/lib/python3.14/site-packages/lutris/exception_backstops.py", line 35, in wrapper
  result = function(*args, **kwargs)
File "/usr/lib/python3.14/site-packages/lutris/game.py", line 687, in configure_game
  gameplay_info = self.get_gameplay_info(launch_ui_delegate)
File "/usr/lib/python3.14/site-packages/lutris/game.py", line 626, in get_gameplay_info
  gameplay_info = self.runner.play() # type: ignore[attr-defined]
File "/usr/lib/python3.14/site-packages/lutris/runners/wine.py", line 1350, in play
  command = self.get_command()
File "/usr/lib/python3.14/site-packages/lutris/runners/wine.py", line 854, in get_command
  raise RuntimeError(_("Proton is not compatible with 32-bit prefixes."))
RuntimeError: Proton is not compatible with 32-bit prefixes.
Lutris log:
[INFO:2026-03-15 11:18:09,330:application]: Starting Lutris 0.5.22
[INFO:2026-03-15 11:18:09,636:startup]: "card1" is NVIDIA GeForce RTX 4080 SUPER (10de:2702 1043:8962 nvidia) Driver 580.126.09
[ERROR:2026-03-15 11:18:40,923:exception_backstops]: SkyDemon (wine) has encountered an error: Proton is not compatible with 32-bit prefixes.
[WARNING:2026-03-15 11:18:40,924:game]: The game has run for a very short time, did it crash?
If anyone else installed SkyDemon lately under Linux, I would appreciate any help since I tried several different ways to get it running, but to no avail.
Joachim Zach
J
Belga - 3/15/2026 10:48:55 AM
Hi b3nn0,
Lutris log:
I recently managed to get it working under debian trixie with the standard wine-stable from this distribution (version 11.0.0.0~trixie-1) without any additional software like proton. To install the reqired dotnet versions I used winetricks (version 20250102-next). My winetricks-log for that looks like this:
winxp
dotnet40
dotnet45
dotnet46
dotnet461
dotnet462
dotnet472
I don't really know, why this winxp is listed here. Maybe from an older run.
As far as I can see, SkyDemon v4.2.3.0 is running properly here.
The winetricks version is not the most recent one from upstream, but it did the job.
