SkyDemon on Linux
http://forums.skydemon.aero/Topic18508.aspx
By Dario70 - 4/3/2016 9:37:22 AM
Hello all,
For all Linux user that want use Skydemon on linux :
http://www.bytebang.at/Blog/Running+SkyDemon+under+Linux+with+wine
Link
Work 100% on Arch.
Happy landings.
By specialized_ken - 5/18/2026 8:19:16 AM
specialized_ken - 4/27/2026 8:46:13 PM
KNOWN LIMITATIONS
  • Approach plate map overlay crashes Wine. Displaying approach plates as a map overlay (not the standalone plate browser) triggers a crash in Wine's GDI+ library.This is a Wine bug triggered by the PDF rasterizer used by SkyDemon (TallComponents.PDF.Rasterizer). The upstream fix is in Wine master (commit 7ece436, "gdiplus: Bypass span combination for intersected rects",April 2026) but has not appeared in a release as of Wine 11.7. Workaround: use SkyDemon's built-in plate browser (Charts → Approach Plates) instead of the map overlay. The standalone browser is unaffected. This should be fixed automatically once wine-staging picks up the fix from Wine master, likely in Wine 11.8 or later.
Confirmed fixed with Wine 11.9
