Planned route on Google Earth
ikarus61
ikarus61
Posts: 21, Visits: 79
I'd like to see, the route I prepare in planning mode, in Google Earth, in the same way today it's possible to see a flight log.
It would be very useful to study the route and the landscape you'll find once in flight.
Massimo Mangia
I-PPL
ikarus61
ikarus61
Thanks for your suggestions. It would be however easier to have this option embedded in SD (in a menu). It's just a command line to insert in the source code.
Massimo Mangia
I-PPL
Daniel_KDF
Daniel_KDF
Posts: 57, Visits: 396
I am planning a route in mountainous terrain, and I also would love to get a 'google earth track/route' of my planned route ahead. This would make VFR flight familiarization so much easier.
I saved to route to GPX and imported it in Google Earth, however, it seems that the elevation of my waypoints is set to the GND elevation and not to the elevation of my planned route. This makes this feature much less useful than I hoped it would be.
Am I doing anything wrong? Is there a way to get a useful Google Earth/GPX of my planned route, including planned altitude?
Boss
Boss
Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)
Posts: 1, Visits: 0
‌‌Is there any news since the last post of Daniel. I would also be interested to see the elevation in the exported gpx file to be used in Google earth based on the planned altitude.
Is there a way‌‌ to do so ?
Thanks a lot in adv‌‌ance.
Bumelbee
Bumelbee
Posts: 23, Visits: 201
Boss - 11/19/2016 11:17:24 AM
Same countes for me. Is there any news? It would be very useful, especially planing routes above the alps! I really miss this important feature.
Best regards
NoDoc
N
Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)Too Much Forum (205 reputation)
Posts: 5, Visits: 1
Maybe SD wants to have a look, how this should work:
http://fl95.de/index.php
look for "Laden/Speichern/Drucken" and
then "3D Ansicht in GoogleEarth"‌‌
SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)
Posts: 7.8K, Visits: 8.4K
This is not a very popular request, so it's not on our development list at the moment.
Pointing us to other software which does implement the feature does not help.
Gottfried Razek
G
Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)Too Much Forum (93 reputation)
Posts: 1, Visits: 0
Hi, I was looking for the same feature and after reading this post found a way to do it with the current version of SkyDemon.
Step1: Save your route as a GPX file (Route->Save As with GPX as file type).
Step2: Open Google Earth and do a File-‌>Open on the saved route (check all checkboxes in the open dialog).
The route is drawn flat on the ground, because the altitude info in the GPX file obviously is SkyDemon proprietary, but
I like it anyways. Hope this helps.
Jörg Hofmann
Jörg Hofmann
Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)Too Much Forum (557 reputation)
Posts: 8, Visits: 5
I tried to find my post/thread and found yours here. So, maybe we have a solution here in my thread? Lets try...
http://forums.skydemon.aero/Topic25168.aspx
