GPX, KML, KMZ Ex-/Import with Google Earth
Jörg Hofmann
Jörg Hofmann
Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)Too Much Forum (687 reputation)
Posts: 8, Visits: 5
Hi everybody.
Are there some GoogleEarth Specialists here?
Flightlogs can be displayed relatively simply and well in Google Earth.
But i want: A in SD planned flight (e.g. the austrian alps region) Pre-View in Google Earth also. Not also as track on ground, i just want to see (and "feel" theoretical) how my planned altitudes are safe for me, cause in Google Earth i can see neighboring terrain.
Can i arrange this? how?
pgroell
pgroell
Posts: 106, Visits: 18K
I do the following on a PC.
- save the route as GPX file
- op‌en GPX file with Google Earth (I am using the free Pro version)
- upon import, Google Earth opens a pop-up asking a few options, select all the options.
You are done.‌
Jörg Hofmann
Jörg Hofmann
Posts: 8, Visits: 5
pgroell - 1/16/2018 10:21:03 AM
You are done.‌
Ok. Same here. But after importing i see the planned Track lying on the ground. The planned altitudes where not considered!?
pgroell
pgroell
trallala666 - 1/18/2018 11:29:07 AM
You are done.‌
A I understand it, it is because the planned altitudes are not part of the elements considered by Google Earth.
See‌ below the format of a reporting point in GPX
<rtept lat="48.458140" lon="3.533306">
  <ele>95.0000</ele>
  <name />
  <extensions>
   <skd:level type="A" value="4500" />
  </extensions>
<ele‌‌> is the elevation of the reporting point in meters
‌<skd:level type="A" value="4500" /> is the planned altitude (type = "A")
Google Earth only uses the <ele> part and not the planned altitude which seems proprietary information for Skydemon.
‌I think that to do what you want you would have to create a routine to reformat the GPX file to a KML file.
Edited 1/19/2018 10:00:54 AM by pgroell
pgroell
pgroell
pgroell - 1/19/2018 10:00:54 AM
You are done.‌
  <ele>95.0000</ele>
  <name />
  <extensions>
  </extensions>
I found a kind of solution to your problem but you have to experiment a bit.
First you will need to open the GPX file with a text editor (Notepad ++ or any other), and replace
with
<altitude>4500</altitude>
for every  leg you have created ( if you don't change altitude or level too me‌‌uch then bulk Search and replace works).
You might have to delete the‌‌  <extensions> and  </extensions> lines (I deleted them but have no time to test with the lines undeleted).
Then go to this website
http://www.gpsvisualizer.com/map_input?form=googleearth
 It will create a KMZ or KML file from the GPX file.‌
‌There are many options, you will have to experiment.
It is akward but it works.
Edited 1/19/2018 10:50:14 AM by pgroell
Jörg Hofmann
Jörg Hofmann
Posts: 8, Visits: 5
I will try asap and will report here. So much thanks for the moment, i think you got it!
Jörg Hofmann
Jörg Hofmann
Posts: 8, Visits: 5
So - this works. Great. But the way is a bit long :-( Anyway, THANK you so much, pgroell!
Let me summarize the steps:
1) Open the SkyDemon outputed GPX File with a Text-Editor.
2) rep‌lace lines like <skd:level type="A" value="4500" /> with  <altitude>4500</altitude>
3) remove <extensions> and  </extensions> lines. This has to been done!
4) save the GPX File and close it
5) load up this GPX File here: http://www.gpsvisualizer.com/map_input?form=googleearth right side of the window!
6) change these settings in the left half window, middle section: Altitude mode  to "extruded" . choose also line width and desired colour and change the units (left window on top) to nautical!
7) klick on "Create KML File" on the right side. Wait.
8) open / import the produced Kml File to Google Earth
9) Enjoy ;-)
Edited 6/6/2018 9:16:43 PM by Jörg Hofmann
emporer
e
Posts: 69, Visits: 5
I have for you this workaround:
- plan your route in SD
-simulate the flight in SD or fly it in a flight sim
- a log file will be generated by SD
- select the log file and open it in google earth, you will see your track elevated over ground in whatever altitude you were simulating it
emporer
e
Jörg Hofmann
Jörg Hofmann
Posts: 8, Visits: 5
emporer - 6/6/2018 10:03:20 PM
Pls what? For about 3 hr. Trip i should wait at least 2hr. to get a log file written? Crazy...Hehe
