Crash creating a route
rpc41
rpc41
Posts: 9, Visits: 98
That did the trick. I delete the FIR definitions. I created this data a while ago before I found out FIR's are not needed.
That makes it look rather like your custom data is causing the problem. Check the identifiers you have used. In particular, if you have defined a flight information region, it MUST have an identifier and that identifier must be a standard ICAO four-letter format.
rpc41
rpc41
Attached is the output after a crash.  I was attempting to create a route in Nambia.  THe airfields have been created as Custom Data. This information is from version  V2 Beta but 1.4.4 also does the same.
System.ArgumentException: Invalid identifier specified:
Parameter name: identifier
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.Invoke(SkyDemonAction method)
   at Divelements.Aviation.Routing.PenetrationCalculation.CalculateAsync()
   at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.xc1bd39b0591195f7(Object x92c17a18c13dd85c)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.4.5.32593
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.4034.32591
    Win32 Version: 1.0.4034.32591
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.SandGrid
    Assembly Version: 2.2.4.1
    Win32 Version: 2.2.4.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
