Crash creating a route
http://forums.skydemon.aero/Topic1774.aspx
By rpc41 - 1/24/2011 8:33:41 AM
Attached is the output after a crash.  I was attempting to create a route in Nambia.  THe airfields have been created as Custom Data. This information is from version  V2 Beta but 1.4.4 also does the same.
System.ArgumentException: Invalid identifier specified:
Parameter name: identifier
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.Invoke(SkyDemonAction method)
   at Divelements.Aviation.Routing.PenetrationCalculation.CalculateAsync()
   at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.xc1bd39b0591195f7(Object x92c17a18c13dd85c)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
SkyDemon
    Assembly Version: 1.4.5.32593
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.4034.32591
    Win32 Version: 1.0.4034.32591
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
System
System.Drawing
Divelements.SandGrid
    Assembly Version: 2.2.4.1
    Win32 Version: 2.2.4.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
By rpc41 - 1/24/2011 6:48:34 PM
That did the trick. I delete the FIR definitions. I created this data a while ago before I found out FIR's are not needed.
