hucbr600
hucbr600
Posts: 20, Visits: 240
Hi All,
Just moved from a PC to a Mac running Mojavie 10.14.5.
Is there an easy to follow guide on how to instal and run SkyDemon on my machine.
I've read the thread and come across things like winebotlle wrapper or similar - I have no idea what this means.
Many thanks
SmoothFlyer
S
Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)
Posts: 11, Visits: 58
peter.kesten - 7/5/2019 2:09:11 PM
Hmmm ... this happened usually when one tried to update oft of the last version by Rikur.This should definitely not happen when having the version by Cessnaoui installiert as a base and then doing an Update out of this version. Are you really sure, that you are using the package wrapped by Which version shows the Skydemon you are running?Regards, Peter
Ok I finally got everything working again, including updates.
I uninstalled Sky Demon for Mac using AppCleaner and then removed hanging directories  as suggested by Rikur in an earlier post:
rm -rf $HOME/Documents/SkyDemon
rm -rf "$HOME/Library/Application Support/Divelements Limited/"
I then reinstalled Sky Demon using Cessnaoui's build. I had to wait for a bit whilst Wine update itself. That's all.
Thanks for you help and suggestions.
Edited 7/5/2019 3:27:06 PM by SmoothFlyer
peter.kesten
peter.kesten
Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)
Posts: 18, Visits: 14
Regards, Peter
SmoothFlyer
S
Unable to upgrade to newer version of SkyDemon. When trying to upgrade this message pops up!
"SkyDemon requires Microsoft .NET Framework 4.5"
SmoothFlyer
S
Cessnaoui - 6/18/2019 3:41:21 PM
SmoothFlyer - 6/14/2019 10:11:46 AM
Cessnaoui - 5/12/2019 1:56:56 PM
Thanks to the guidelines of Peter, I have been able to make a version that is working on my iMac Late 2013 with High Sierra.
Please find here the link to download the package: https://drive.google.com/file/d/1nHQEjz9QqYsAd2K16XseNWoW1rcLCx75/view
The zip file contains the "Skydemon for Mac.app" that you have to copy to your "Application" folder.
This version seems to be stable. I encountered one or two crashes but nothing blocking the use of the application.
Please note that I already had that behavior on previous versions of Skydemon for Mac.
Good luck and have safe flights.
I have an old iMac running macOS High Sierra 10.13.6
Skydemon for Mac keeps crashing when trying to scroll or zoom. I have not been able to test other functionality due to the crashes. May have to revert to using it under Windows using Boot Camp.
Strange, I'm using same version of MacOS and it works correctly.
Another possibility is to install a virtualized Windows using VirtualBox.
It is working very nicely and is more stable.
VirtualBox is free but of course you need a Windows licence.
I have reinstalled this version and seems to be working fine now. Thank you!
Cessnaoui
Cessnaoui
Posts: 32, Visits: 0
MarkusM - 6/23/2019 7:09:42 AM
Mercy vielmals for preparing this! Only one little thing - if you do a next pull from your setup, could you please switch to system language english before? The wrapper you are using does not recognize multi-language and puts the SkyDemon folder in 'Mes documents' which is not mapped correct on a non-French host system. Took me an irritating moment to find my log files ;-).
Thank you for mentioning this. I will take care next time ;-)
pilot-byom
p
Posts: 323, Visits: 388
Edited 6/23/2019 7:10:16 AM by MarkusM
Cessnaoui
Cessnaoui
SmoothFlyer
S
peter.kesten
peter.kesten
realatc - 6/14/2019 7:31:29 AM
Thanks for advise, Peter. Will stop all my flights and wait until print is done )
Thank you.
You are welcome. Please report, if this solves the problem.
