Estonian map
Flying Tiger
Flying Tiger
Posts: 24, Visits: 77
Hi SD team!
There was an update of the Estonian VFR chart in May 2015. If you compare the pictures below of the same area, you'll notice that the shape of the Tallinn TMA1 area is not correct in SD.
Also the shapes of the "Low level military flying areas" are not entirely correct in SD. The biggest difference is that the borders should follow the TMA and FIZ boundaries and not go inside them as they do in the SD map. See picture of these areas from the Estonian AIP below:
It would be much appreciated if you could take a look at this.
Cheers! Kaj
Thanks for reporting this, we are looking into it.
I can confirm we have corrected the piece of controlled airspace you mentioned. Thank you again for bringing it to our attention; the problem was that it was not very well described in the AIP. After studying it carefully and with reference to the other chart you posted, we have now depicted it according to what we believe they were trying to express. A new chart has been issued.
We will get to the low-level areas next week.
Flying Tiger
Flying Tiger
Only 5 hours after my first posting, and you have already corrected the chart !! You are amazing, thank you very much Skydemon-team !!Smile
Cheers! Kaj
Flying Tiger
Flying Tiger
After the latest chart update, there still seems to be a small inaccuracy regarding the "Central low level military area" around the EEPU/Parnu FIZ boundary. If you compare the SD chart with the chart from the Estonian AIP (below) you'll notice that the southern border of the "Central low level military area" should follow the northern part of the EEPU/Parnu FIZ boundary, not the southern part, as it is doing now in SD.
Otherwise everything else looks correct.
-Kaj
Thanks, we will tweak that detail ready for the next AIRAC day.
