By Flying Tiger - 11/5/2015 10:10:02 AM
Hi SD team!
There was an update of the Estonian VFR chart in May 2015. If you compare the pictures below of the same area, you'll notice that the shape of the Tallinn TMA1 area is not correct in SD.
Also the shapes of the "Low level military flying areas" are not entirely correct in SD. The biggest difference is that the borders should follow the TMA and FIZ boundaries and not go inside them as they do in the SD map. See picture of these areas from the Estonian AIP below:
It would be much appreciated if you could take a look at this. Cheers! Kaj
By Tim Dawson - 11/13/2015 10:43:05 AM
Thanks, we will tweak that detail ready for the next AIRAC day.
