Cannot open FPL from cloud storage
Bustelli
Bustelli
Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)Too Much Forum (815 reputation)
Posts: 9, Visits: 25
Ipad mini IOS 8.4.1
Skydemon 3.4.0.14
I generated a new FPL on my PC and saved it to my cloud storage. I was able to open it on my Android smartphone so the FPL must have been saved succesfully, but I was not able to open it from my Ipad. I have already restarted and logged in (Skydemon) the Ipad but without success. The Ipad has full Internet access (Wifi) but Skydemon also does not download any flight data (Notams, Weather) when I generate a FPL on the Ipad directly. It always shows an error message that there ist no Internet connection/cloud storage not available. Thanks for any help, planning a nice flight tomorrow...
Michael
I'm afraid it's impossible to say other than the obvious suggestion which is to ensure there is, in fact, an internet connection. If there isn't, then what you described will happen.
Bustelli
Bustelli
"Problem" solved - Skydemon was in offline modus because I used it as a backup device on my last flight.
efrenken
efrenken
Posts: 265, Visits: 3.5K
Hi Bustelli,
When you use SD as backup in flight, turn it online before takeoff. You probably won't have internet connection when you need it, which is absolutely necessary to switch it into online mode.
Eric
