SkyDemon 3.3.2 Beta
There is currently a public beta for our Android and PC products. SkyDemon 3.3.2 contains the following changes:
Touching a leg temporarily reveals its distance, time and magnetic heading, and unlocks it for rubber-banding when navigating (iOS, Android, PC)
Improvements to flight log analysis makes it possible to intuitively review the statitics in detail by dragging the aircraft (iOS, Android)
There is now an in-app tool to automatically download the UK Postcode file if you search for one and the file isn't there (iOS, Android, PC)
Legibility improvements to the display of other traffic received via Flarm and ADS/B devices (iOS, Android, PC)
It is now possible to use the "Land Here" functionality at user waypoints (iOS, Android, PC)
Alongside Sunrise and Sunset we now also show MCT and ECT, as the start and end of civil twilight (iOS, Android, PC)
The "What's Here?" menu has been improved to split airspaces away from other information making it more intuitive (iOS, Android)
Searching for waypoints containing accented characters is now much easier as the accents are no longer required in search text (iOS, Android, PC)
64bit support added (iOS)
T67M
T67M
Posts: 206, Visits: 3.2K
I love the attention to detail! On short legs, in planning mode, the touch popup shows the distance, while in flying mode, it shows the bearing. Perfect!
srayne
srayne
Posts: 388, Visits: 8.3K
I've been playing with the new Beta for a few days and can't break it (Android & PC). Great stuff.
One problem I have (not new to this beta) is that viewing the live PLOG on Android and scrolling down into the frequencies section then after a few seconds the display jumps back to the top of the PLOG. This is inconvenient when I have frequencies displayed ready for the next QSY and look down to find that they are no longer visible.
Simon
Thanks, we will add some code to work around that.
srayne
srayne
Tim Dawson (6/30/2015)
I've just noticed this also happens (on Android) when viewing the PLOG from the planning screen as well as the live PLOG.
Simon
The beta has been updated, with the following additions:
The TAF and METAR briefing can now be sorted by distance along route as well as alphabetically (iOS, Android, PC)
The addition of a Help menu facilitates easy access to the User Guide (iOS, Android)
I have just updated the beta again, with the following changes:
Dynon SkyView integration is enabled. To use it, specify that you have a SkyView under the Setup -> Connectivity menu. You will then be offered the opportunity to use the SkyView when you press Go Flying. The SkyView will then be the source for your GPS data, and there will be an option under the Route menu called "Send to Dynon SkyView" which will instantly transfer your route to the SkyView. Obviously, all this requires that your SkyView is equipped with the Wifi dongle option and your Android device is connected to the SkyView's Wifi hotspot.
This feature should be regarded as a prototype and we will not necessarily include it in the next version of SkyDemon. We do want your feedback on it, though.
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
Tim
I had a CTD here and there on my TabPro using the two new betas. I can reproduce the crash by opening the 'What is here?' window on a specific point and get the information about the airspace. SD will crash immediately or by zooming in or out. Version 3.3.1 is running fine, though.
-mike
Edited 7/8/2015 1:32:31 PM by Mike@EDTG
Thanks, what is the specific point you mentioned please?
Mike@EDTG
Mike@EDTG
Spain POS VOR (Mallorca) tap nearby - What is here window shows waypoints. Taping on the waypoints (coordinates or create waypoint) worked fine - closing window by taping aside included. Choosing an item under airspace & closing the window gives you an immediate CTD or after closing followed by a pinch to zoom. Worked elsewhere, but that´s the one I could remember.
thx
-mike
