Problems in reversing the route in navigation and with displaying weather in planning (Android)
srayne
srayne
Posts: 388, Visits: 8.3K
Flew to Bembridge yesterday and SD behave flawlessly. I left my Nexus in the cockpit in navigation mode. On return I selected Route/Reverse without leaving nav mode and checked the PLOG which looked OK.
After takeoff the instruments did not register that this was a new flight and were still showing DST and ETE threshold at Bembridge. The position instrument was also showing 'approaching EGHJ Bembridge Runway 30'. Only way I found to fix this was to exit to planning mode and then return to navigation mode at which point all was correct again.
Another bug on Nexus 7 Android: In planning mode, select an airfield 'plate' by tapping the 'i' symbol next to an airfield (or press and hold on airfield and select 'Information' from the context menu). Then in the SkyDemon's plate window select TAF or METAR and when the weather is displayed tap on the first line  (e.g. "TAF for London Luton (EGGW)").  Then get I an error "Web page not available, The Web page at ios:entityClick(EGGW) could not be loaded...".
Simon
Unfortunately after trying quite hard in the simulator, I was not able to reproduce the problem you are describing. Literally as soon as I reversed the route (while still in navigation mode) the ETA box etc stopped talking about the threshold and talked about my next waypoint. Can you reproduce this at all?
I reproduced the bug in the weather window and it's been fixed; thanks.
hucbr600
hucbr600
Posts: 20, Visits: 240
Exactly the same has happened to me on the last 2 trips (Sywell and Bournemouth).
hucbr600
hucbr600
P.S - Oops - forgot to add I'm using an IPad mini and not an Android platform.
My same question applies.
