By srayne - 5/31/2015 10:40:38 AM
Flew to Bembridge yesterday and SD behave flawlessly. I left my Nexus in the cockpit in navigation mode. On return I selected Route/Reverse without leaving nav mode and checked the PLOG which looked OK.
After takeoff the instruments did not register that this was a new flight and were still showing DST and ETE threshold at Bembridge. The position instrument was also showing 'approaching EGHJ Bembridge Runway 30'. Only way I found to fix this was to exit to planning mode and then return to navigation mode at which point all was correct again.
Another bug on Nexus 7 Android: In planning mode, select an airfield 'plate' by tapping the 'i' symbol next to an airfield (or press and hold on airfield and select 'Information' from the context menu). Then in the SkyDemon's plate window select TAF or METAR and when the weather is displayed tap on the first line (e.g. "TAF for London Luton (EGGW)"). Then get I an error "Web page not available, The Web page at ios:entityClick(EGGW) could not be loaded...".
Simon
By Tim Dawson - 6/3/2015 4:41:41 PM
My same question applies.
