Visits: 78
currently, SkyDemon (3.3.0.0 for Windows PC) crashes whenever I open the Weight & Balance tab for the second time. I.e. upon running SkyDemon, I can have a look at it once, but the second time I get an exception. Details below.
Patrick
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at Divelements.SkyDemon.Briefing.WeightBalancewindow.LoadingPointGridRow.GetCellValue(GridColumn column) at Divelements.SandGrid.GridRow.DrawCells(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats) at Divelements.SandGrid.GridRow.DrawRowForeground(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats) at Divelements.SandGrid.InnerGrid.x14295bd0cde2ff5d(RenderingContext x0f7b23d1c393aed9, Boolean x48d1c33294a7dd40) at Divelements.SandGrid.InnerGrid.x7f63857195e5d213(RenderingContext x0f7b23d1c393aed9) at Divelements.SandGrid.SandGridBase.OnPaint(PaintEventArgs e) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at Divelements.SandGrid.SandGridBase.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m) at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- SkyDemon Assembly Version: 3.3.0.34021 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Divelements.Aviation Assembly Version: 3.3.0.34019 Win32 Version: 3.3.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL ---------------------------------------- Divelements.SandGrid Assembly Version: 2.2.4.1 Win32 Version: 2.2.4.1 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL ---------------------------------------- SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL ---------------------------------------- TallComponents.PDF.Rasterizer Assembly Version: 3.0.105.0 Win32 Version: 3.0.105.0 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Divelements.Mapping Assembly Version: 3.3.0.34019 Win32 Version: 3.3.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL ---------------------------------------- SandBar Assembly Version: 1.4.3.2 Win32 Version: 1.4.3.2 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandBar.DLL ----------------------------------------
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
