Exception each time I open the W&B tab the second time (per program execution)
http://forums.skydemon.aero/Topic15854.aspx
By Patrick - 5/26/2015 7:46:04 PM
currently, SkyDemon (3.3.0.0 for Windows PC) crashes whenever I open the Weight & Balance tab for the second time. I.e. upon running SkyDemon, I can have a look at it once, but the second time I get an exception. Details below.
Patrick
System.NullReferenceException: Object reference not set to an instance of an object.
   at Divelements.SkyDemon.Briefing.WeightBalancewindow.LoadingPointGridRow.GetCellValue(GridColumn column)
   at Divelements.SandGrid.GridRow.DrawCells(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats)
   at Divelements.SandGrid.GridRow.DrawRowForeground(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats)
   at Divelements.SandGrid.InnerGrid.x14295bd0cde2ff5d(RenderingContext x0f7b23d1c393aed9, Boolean x48d1c33294a7dd40)
   at Divelements.SandGrid.InnerGrid.x7f63857195e5d213(RenderingContext x0f7b23d1c393aed9)
   at Divelements.SandGrid.SandGridBase.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at Divelements.SandGrid.SandGridBase.WndProc(Message& m)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
SkyDemon
    Assembly Version: 3.3.0.34021
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
System
System.Drawing
Divelements.Aviation
    Assembly Version: 3.3.0.34019
    Win32 Version: 3.3.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
    Assembly Version: 2.2.4.1
    Win32 Version: 2.2.4.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
    Assembly Version: 3.0.105.0
    Win32 Version: 3.0.105.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
SandBar
    Assembly Version: 1.4.3.2
    Win32 Version: 1.4.3.2
    CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
By Tim Dawson - 5/27/2015 9:51:03 AM
You will find that if you upgrade to the latest version, this bug has been fixed.
