Skydemon and Android Problem?
dyker124
dyker124
Posts: 10, Visits: 11
I have recently purchased an Asus Memopad 7 (7") ME176CX Tablet to take the place of my iPad Mini since Apple updated its system to 8.3. The external GPS I have is a XGPS150A which always worked fine with the iPad.The new tablet has Android 4.4.0 installed.
The problem I have is that Skydemon keeps exiting the program back to the tablet 'Home' screen. Either that or the screen freezes with the massage 'Skydemon not responding'. I am using a helper APP for the external GPS as suggested and until crashing works fine.
I have been made aware that the tablet I'm using has the Intel Atom processor in it and there is a suggestion that it is not compatible with Skydemon.
1) Is this the case?
2) If so, is there a software fix for it?
I'm starting to feel that I've just wasted my money purchasing the tablet.
Roger
Hello Roger,
We have no specific knowledge of the tablet you mention. However if it has an unusual processor type then that might explain any stability problems you have observed. Most Android tablets have ARM processors and it's our understanding that the few exceptions feature emulation layers so they pretend to be ARM compatible. Anecdotally, we have heard that most complex or demanding apps do not run well in this situation. It's not that the apps have bugs, per se, it's more that the environment isn't giving them what they need to run properly.
Personally I don't know how they can even sell these devices, when they obviously struggle so much to run the apps people are going to want to run on them.
JennyW
JennyW
Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)Too Much Forum (153 reputation)
Posts: 1, Visits: 11
I have a Tesco Hudl2 which has similar problems with randomly closing Skydemon and I just checked - it too has an Atom processor.  Annoying if there isn't likely to be any sort of fix
Jenny
dyker124
dyker124
Thanks for your reply. Looking on the web I notice that a lot of the newer Tablets coming onto the market are now using Intel's Atom Processor whereas the older Tablets used the ARM. Will that mean that more and more of the newer Tablets coming out will not be able to use SkyDemon?
Roger
It's too early to say at the moment. We may be able to produce a build designed to work on these tablets without an emulation layer but we'd need to research it first.
Tonimarconi
Tonimarconi
Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)Too Much Forum (133 reputation)
Posts: 1, Visits: 1
I have the same problem with a Nexus 7 tablet (2013). This tablet has a quadcore Qualcomm Snapdragon S4 Pro-processor.
Previous year i had no problems with Skydemon, however since this year the app regularly crashes especially when circling (glider). Skydemon just shuts down and i have to restart it. Maybe its because of an Android update or Skydemon update.
Any more Nexus 7 users who have this problem?
Tonimarconi (5/20/2015)
I have a Nexus 7 (2013) running the latest Android and SD versions and I have experienced no problems whatsoever. SD is as solid as a rock.
26200.7840, SD 4.2.3
segillum
segillum
Posts: 14, Visits: 166
>I have a Nexus 7 (2013) running the latest Android and SD versions and I have experienced no problems whatsoever. SD is as solid as a rock.<
+1
DirDej
DirDej
Posts: 120, Visits: 1.5K
My Nexus7 2012 running 5.1.1 is solid as a rock as well. Using external GNS2000 GPS.
As an update to this thread, I should mention that the latest public version of SkyDemon now includes native x86 support which makes SkyDemon very stable and faster on devices with x86 processors.
We do not know of any bug in SkyDemon which systematically affects stability across a broad range of devices.
Isolated crashing is still a problem of course but it's much more likely to be down to a specific device. If there are any crash logs available we would happily take a look at them, of course.
