Charts and Aeronautical Data
Airspace with sloping lower limit
DirDej
DirDej
posted 2/19/2015 7:24:41 PM
Visits: 1.5K
EBR25 - KOKSIJDE CLIMB-OUT
Lateral limits
Vertical limits
Type of restriction / nature of hazard
Time of activity
504235N 0025545E - 510045N 0023852E - 505900N 0024917E - 504626N 0030102E - along the Belgian-French border - 504235N 0025545E.
4500 ft AMSL / 1100 ft AMSL
(1)
Climb-out sector for jet aircraft. Crossing clearance shall be requested from Koksijde APP.
During
EBFN
OPR HR
(2)
(1)
1100 ft AMSL from lateral limits of
Koksijde CTR
to 16 NM from the ARP on an axis of 150 DEG GEO, then a slope of 5°30' to the extreme limit of this sector.
(2)
EBFN
OPR HR can be checked with Brussels FIC or Semmerzake ATCC.
As you can see from this AIP text note, the EB-R25 airspace has a sloping lower limit. Is there a way this can be represented in SD? Following the SD chart, flying between EBKT and LFQT for example, you would be flying much lower than needed if you want to avoid R25.
posted 2/20/2015 12:46:23 PM
Posts: 8.2K,
Visits: 9.6K
No. This is an absurd notion, and we don't think it's likely to catch on.
