skydemon logo blocks Ground Speed on my nexus in horizontal mode
toneee1
toneee1
Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)Too Much Forum (816 reputation)
Posts: 6, Visits: 10
Hi Tim and All
just flown tonightwith my nexus 7
for some reasonthe skydemon logo in "flying mode"
now blocks myground speed (indicator on the vertical bars/GS/DIST END/ETE NXT/ALT/TRK/WINDetc)
any way of makingthis logo smaller or moving the "bars" down
if i use the nexus vertically no probs , but i can’tdo this in my a/c without blocking other instruments/controls
android v3.1.1.25964
thanks
If there isn't enough room for the instruments you have selected, you will need to deselect an instrument. You can do this from the inflight Setup -> Instruments screen.
srayne
srayne
Posts: 388, Visits: 8.3K
I think there's a bug here - attached screenshot from nexus 7 after rotating the screen.
You've got way more instruments selected than would have been on by default. There really isn't much we can do here; if you select more instruments than will fit, then they won't fit properly.
srayne
srayne
Tim Dawson (11/4/2014)
Here's the same with only one instrument (GS) enabled!
toneee1
toneee1
also
this has only just happened
it was ok up to a few weeks ago
with the same instruments
nothing has been changed by me
toneee1
toneee1
ps
been using the same  nexus for over 18months now !
ipad ok
no probs
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
Happens on my TabPro 8.4 too, but only when changeing screen orientation from portrait to landscape or vice versa during flight.
-mike
toneee1
toneee1
Sorted it now
Went into instrument settings and altered the Font size to .8 which also reduces the skydemon logo
So alls well again
Regards tony
Hmm, I hadn't noticed that the instruments being displayed were actually the planning-only instruments. I will look to see what might be making them reappear.
