User Waypoint Properties
John Mead
John Mead
Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)Too Much Forum (360 reputation)
Posts: 3, Visits: 8
I'm using SD 3.1.0.0 on Windows 7 PC   , also on iPad mini.  When I create a user waypoint as an airfield it does not seem to be recognised as an airfield in a multi-sector route ; ie I am not offered the Land Here option.   Is this a system fault , or is there something else that I need to do ?
John Mead
You cannot create a user waypoint "as an airfield". User waypoints are user waypoints.
There does exist an advanced tool with which you can actually create airfields and other aeronautical data; it's bundled with SkyDemon Plan and once your data has been created on a PC it can be shared to mobile devices via the cloud. This might offer you a better solution. Alternatively, if the airfield owner is happy for us to do so, we can add it to our charts.
John Mead
John Mead
Posts: 3, Visits: 8
Thanks Tim,
                   that does  seem to make the waypoint creation dialogue a little mis-leading .   I've located the Custom Data section, so hopefully the problem will be solved.
John
In what way is it misleading?
