Visits: 215
Hi Tim, I was playing a bit with downloadable plates and found that on Windows the Folder C:\Users\xyz\AppData\Roaming\Divelements Limited\SkyDemon Plan\Plates had the requested plates downloaded.
On Android, however, the Folder ist not under Skydemon, but under /data... which is protected and can only accessed when you root your device Especially for _Austrian Maps These are 20+ Mbyte large, but can be easily substituted with "flat" PDF maps which are just 1,4 or so kb large and therefore load very quickly.Do you have any plans for the Android Version to make the maps Directory more accessible ?? thanks
Erik
