MAPS Directory
http://forums.skydemon.aero/Topic13497.aspx
By rosdol - 10/7/2014 7:25:10 PM
I was playing a bit with downloadable plates and found that on Windows the  Folder C:\Users\xyz\AppData\Roaming\Divelements Limited\SkyDemon Plan\Plates had the requested plates downloaded.
On Android, however, the Folder ist not under Skydemon, but under /data... which is protected and can only accessed when you root your device
Especially for _Austrian Maps These are 20+ Mbyte large, but can be easily substituted with "flat" PDF maps which are just 1,4 or so kb large and therefore load very quickly.Do you have any plans for the Android Version to make the maps Directory more accessible ??
thanks
Erik
By Tim Dawson - 10/8/2014 3:55:14 PM
No, the PDFs are not intended to be user-accessible.
