Multi-Sector Planning: Fuel
We plan to expand our multi-sector planning functionality in future versions of SkyDemon. If you think that improving the fuel selection settings so that you can tell SkyDemon you won't be adding fuel at a landing stop is the next thing we should work on, here is a good place to post. How do you think it should work?
Perhaps in the pop-up which allows you to specify how much fuel you will start with, there should be an option to select the fuel remaining from the previous sector?
Threaded View
