Multi-Sector Planning: Fuel
http://forums.skydemon.aero/Topic13233.aspx
By Tim Dawson - 9/8/2014 4:09:32 PM
We plan to expand our multi-sector planning functionality in future versions of SkyDemon. If you think that improving the fuel selection settings so that you can tell SkyDemon you won't be adding fuel at a landing stop is the next thing we should work on, here is a good place to post. How do you think it should work?
Perhaps in the pop-up which allows you to specify how much fuel you will start with, there should be an option to select the fuel remaining from the previous sector?
By ckurz7000 - 9/10/2014 3:44:49 PM
I second that. As a default, assume no additional fuel is taken on at a Point of Landing. The user can then easily change the fuel on board from the calculated amount, in which case the updated amount will be carried forward for all successive legs. Ditto with EOBT and successive ETAs.
