Flight Logs no longer available from Cloud
Peter272
Peter272
Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)Too Much Forum (833 reputation)
Posts: 7, Visits: 167
Just upgraded my SD on the Nexus 7 to 3.0.7 and had a flight today. Afterwards I backed up the log to the Cloud. When I got back home, I tried to open it from the Cloud on my backup device - an iPad 1 running 3.0.3 for iOS.
It failed with the message 'Input string was not in the correct format'
Do I assume that as SD gets updated the format of logs has also changed and will no longer be usable on older iPads that no longer receive version updates?
Yes, that is correct, the log format has changed. Older versions (prior to 3.0.6 I believe) will not be able to read flight logs created with 3.0.6+.
Peter272
Peter272
Thanks Tim
A bit of a blow, as this old iPad I was given by a friend is becoming as useful as a chocolate teapot, apart from SD and Solitaire
