Visits: 42
Maybe it's supposed to work like that, but if you Direct to a waypoint after pressing on the Skydemon icon, you will lose the rest of the route on my ipad....this happened to me and I learned another lesson and that is to save the route, not just to the cloud, but also locally because of course I couldn't resurrect the original flight plan without a 3G signal.... However, again by my own trial and error, I found that holding my finger on the new waypoint and then pressing Insert into flightplan does the trick...but be careful not to select direct or again the flightplan will be wiped....I aLso found that it is not possible to remove a waypoint once you Go Flying...and if you stop navigating and try to edit the route the Edit Route option will only appear if ther is a navaid or IFR waypoint in the original plan...but you can drag the route using your finger....you then have to Go Flying again....now you will have the amended route...(but your logging will start again from a midpoint in space!)
