Import Skydemon log into Garmin BaseCamp
B2Spirit
B2Spirit
Posts: 24, Visits: 158
Hi, I have exported (email) my flightlog from Ipad and want to import this into Garmin BaseCamp. I try to import several logfiles, but get an error message from Garmin Base Camp "unknown error opening import file".
The file is a .gpx file which is supported by Base Camp.
Do anyone have any suggestions or have tried to do this?
B2Spirit
B2Spirit
I think I found the error, Garmin BaseCamp does not handle logfiles with speed information in the log file
kerosin
kerosin
Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)Too Much Forum (865 reputation)
Posts: 8, Visits: 196
I got the same issue and confirm that the issue is due to an undocumented <speed> element used in the Skydemon files.
Some application do simply ignore undocumented elements, but Basecamp is strictly checking the GPX-file according to the official xsi:schema "http://www.topografix.com/GPX/1/1/gpx.xsd".
This schema is mentioned in the GPX-file exported by Skydemon, but Skydemon does not comply to it.
<?xml version="1.0" encoding="utf-8"?>
<gpx xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd" version="1.1" creator="SkyDemon for iPad" xmlns="http://www.topografix.com/GPX/1/1">
<trk>
  <name>Thun - Thun</name>
  <trkseg>
  <trkpt lat="46.752890" lon="7.589792">
   <ele>1022.6650</ele>
   <speed>56.074445</speed>
   <time>2014-06-22T15:13:03Z</time>
  </trkpt>
I tried as a workaround to use another element type using <cmt> (comment), but this doesn't work since the official xsi:schema defines the exact order of the elements. A comment <cmt> must be place after the <time> element and not between <ele> and <time>.
In that case we have to wait for Skydemon to fix this in another software version.
Regards, Eric
"Undocumented" <speed> element?
http://www.topografix.com/gpx_manual.asp
