Zero WInd pilot Log
Stefano
Stefano
Posts: 40, Visits: 157
Hi!
I'm trying to print out the pilot log, but I've noticed that it populates TIME column only if I check the 'Perform wind calculations' box.
How can I have the TIME column with time not considering wind?
Thank in advance
You can set the wind to zero for all legs of your flight, from the Weather -> Tools menu.
Stefano
Stefano
I've no such a menu Unsure
I've 'weather' -> 'enroute condition' or 'download weather for chart' or 'show METAR and TAF' or 'show wind' or 'set weather map time'
Edited 3/6/2014 9:37:10 PM by Stefano
srayne
srayne
Posts: 388, Visits: 8.3K
Select "Weather" then "Enroute Conditions". In the box labelled "Route Legs" Ensure that all legs are highlighted then under "Conditions" enter "0/0".
Stefano
Stefano
Thank you! Rolleyes
Stefano
Stefano
mmm... I set up 0/0 for all legs, but when I go to the print center I've all the same wind caluculations.
Stefano
Stefano
Any suggstions?
I can confirm that setting 0/0 for all legs gives 0/0 in the PLOG and therefore nil wind calculations. This was tested on the latest release of SkyDemon Plan for PC.
Stefano
Stefano
mmm... I tried again... I can see 000/00 but... why is there a GS calculated? it should be same as IAS Doze
srayne
srayne
No. When zero wind GS is not the same as IAS, It's the same as TAS which will change with pressure altitude and temperature for a given IAS.
Edited 3/18/2014 8:38:01 AM by srayne
