SkyDemon Navigation
Zero WInd pilot Log
Zero WInd pilot Log
1
2
Next
Jump To Page
Zero WInd pilot Log
Stefano
Stefano
posted 3/6/2014 8:38:39 AM
HOT
Visits: 157
Hi!
I'm trying to print out the pilot log, but I've noticed that it populates TIME column only if I check the 'Perform wind calculations' box.
How can I have the TIME column with time not considering wind?
Thank in advance
posted 3/6/2014 10:29:26 AM
Posts: 8.1K,
Visits: 9.4K
You can set the wind to zero for all legs of your flight, from the Weather -> Tools menu.
Stefano
Stefano
posted 3/6/2014 9:34:03 PM
Visits: 157
I've no such a menu
I've '
weather
enroute condition
' or '
download weather for chart
' or '
show METAR and TAF
' or '
show wind
' or '
set weather map time
Edited
3/6/2014 9:37:10 PM by
Stefano
srayne
srayne
posted 3/7/2014 8:45:35 AM
Visits: 8.3K
Select "Weather" then "Enroute Conditions". In the box labelled "Route Legs" Ensure that all legs are highlighted then under "Conditions" enter "0/0".
Stefano
Stefano
posted 3/10/2014 7:09:50 AM
Visits: 157
Thank you!
Stefano
Stefano
posted 3/14/2014 8:00:35 AM
Visits: 157
mmm... I set up 0/0 for all legs, but when I go to the print center I've all the same wind caluculations.
Stefano
Stefano
posted 3/17/2014 11:21:05 AM
Visits: 157
Any suggstions?
posted 3/17/2014 5:16:21 PM
Posts: 8.1K,
Visits: 9.4K
I can confirm that setting 0/0 for all legs gives 0/0 in the PLOG and therefore nil wind calculations. This was tested on the latest release of SkyDemon Plan for PC.
Stefano
Stefano
posted 3/17/2014 10:29:27 PM
Visits: 157
mmm... I tried again... I can see 000/00 but... why is there a GS calculated? it should be same as IAS
srayne
srayne
posted 3/18/2014 8:37:28 AM
Visits: 8.3K
No. When zero wind GS is not the same as IAS, It's the same as TAS which will change with pressure altitude and temperature for a given IAS.
Edited
3/18/2014 8:38:01 AM by
srayne
1
2
Next
Jump To Page
