SD Mobile v1.4 Installation
Can you confirm the exact make and model of the device in question?
srayne
srayne
Posts: 388, Visits: 8.3K
Not working for me on Airbox Airspace Aware device - I've not tried 1.4.2 on other devices as I don't want to end up with a non-functioning system.
The reason I ask is because this appears to be a device-specific issue.
Is this actually an Airbox Aware device, or have you purchased one of the many on eBay that looks like an Aware (i.e. with the orange stripe)?
You can always backup the SkyDemon Mobile program files on the other devices if you want to try 1.4.2 temporarily.
srayne
srayne
This is an actual Airspace Aware device - I'll try it out on another device and let you know.
srayne
srayne
I installed 1.4.2 on another device and the license in recognised. I Then deleted the installation from my Airspace Aware device and copied the SkyDemon directory onto the Aware SD card from the other device and the Aware still does not recognise the license.
I think that you are correct that this is a device dependent problem. All was fine with version 1.4
Bathman
Bathman
Posts: 64, Visits: 247
Same problem here on my no brand 5" chinese sat nav. I should add I had no problems with 1.4.0
Ok, we're on this and I think I know what the problem is. If you'd like to contact me by email I'll be happy to send a test build over to try out.
srayne
srayne
OK - email sent
Thanks.
srayne
srayne
Thanks Tim,
Version 1.4.3 now fixes the licensing issue for me on my Airspace Aware device.
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
Tim, thanks from me also.
Version 1.4.3 now licensed & working on "Aware" unit.
Regards,
Max.
