Visits: 111
Hi MFC,
I cannot help you with your licensing problems. However, with regards to the "No Charts Loaded" message, SkyDemon now loads the appropriate chart when it gets a GPS signal to reduce boot up time. You can manually load the chart without a GPS signal by opening Chart Manager on the device and selecting 'load' from the options.
I hope this helps,
Richard Avery
