DFS AIP Information
LutzRab
LutzRab
Posts: 6, Visits: 30
I have the German DFS airport plates subscription. Would it be possible to make
the textual part of the DFS AIP also available? There are operation hours and other things
not available otherwise in the text part.
I believe that document is available in the Document Browser (on iPad). Could you check?
RobinHood
RobinHood
Posts: 31, Visits: 129
It is in the Document Browser.
The point is, it's not searchable. You have to scroll hundreds of pages.
Best regards,
Robin Seidelmann
secosu | Consulting & Support
Experts for ERP-Evaluation & ERP-Implementation projects in Europe
No you don't. After going into the Document Browser you select DFS German VFR AIP. The Aerodrome Details and Helipad Details pages are then right at the top of the list, before the aerodrome-specific pages.
RobinHood
RobinHood
ok, depends on witch airfield you are looking for...
e.g. EDMV Vilshofen ist the first document, but the information for EDMV ist on page 102 of 112!
There's (from my point of view) no change to search for information within "Aerodrome Details".
Best regards,
Robin Seidelmann
If you're looking up plates for a specific airfield, you would normally use the Plates window, where they simply appear if your route uses that airfield. Or, you can add that airfield to the window.
The document browser is for browsing. It does have a search field at the top, which should work, and a first-letter index down the right-hand side of the table of contents, but if you're just looking for all plates for a particular airfield, the Plates window is probably a better tool for the job.
RobinHood
RobinHood
thank you.
The point is, that I'm looking for information not available on the plates, but in the Aerodrome Details (DFS German VFR AIP) like oil availability, opening times,...
This information is NOT on the plates you can search. Is there any chance to be able to get result within a document in the document browser?
Best regards,
Robin Seidelmann
No; unfortunately not. It is DFS who have chosen to group this information on airfields into one large textual document instead of publishing individual documents per airfield.
RobinHood
RobinHood
in there own iOS APP (VFRiManual) they split the textdocument up into parts (singe sites out of the long text file) with the texual information for each specific field
Best regards,
Robin Seidelmann
It might be worth asking them if they plan to offer a split version via their plate resellers, such as us, if that is the way you prefer the information to be presented.
