DFS AIP Information
LutzRab
LutzRab
Posts: 6, Visits: 30
I have the German DFS airport plates subscription. Would it be possible to make
the textual part of the DFS AIP also available? There are operation hours and other things
not available otherwise in the text part.
Posts: 8.2K, Visits: 9.5K
If you're looking up plates for a specific airfield, you would normally use the Plates window, where they simply appear if your route uses that airfield. Or, you can add that airfield to the window.
The document browser is for browsing. It does have a search field at the top, which should work, and a first-letter index down the right-hand side of the table of contents, but if you're just looking for all plates for a particular airfield, the Plates window is probably a better tool for the job.
RobinHood
RobinHood
Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)Too Much Forum (5.7K reputation)
Posts: 31, Visits: 129
thank you.
The point is, that I'm looking for information not available on the plates, but in the Aerodrome Details (DFS German VFR AIP) like oil availability, opening times,...
This information is NOT on the plates you can search. Is there any chance to be able to get result within a document in the document browser?
Best regards,
Robin Seidelmann
secosu | Consulting & Support
Experts for ERP-Evaluation & ERP-Implementation projects in Europe
