HELP!! Canot define Profile for Aquila A201
rosdol
rosdol
Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)
Posts: 48, Visits: 215
Hi, I am trying for day's to create a valid Profile for the A210. Problems:
1) Mogas weight is incorreeclty computed 60l of mogas is computed as 45kg instead of 43, 2 (you use 0,75 instead of 0,73kg/l)!
2) I cannot design a correclty functioning WB/CG Range plot for this machine. I have attached the weighting sheet and the CG Load sheet for you. Can you please come up with a solution ?? I can design the polygon but as soon as I add the empty weight arm it is reddish and off the drawing.
And yes I have read the entry explaining this, but it got not better
Thanks in advance for any solution
Erik
Wiegblatt OE-AKI.pdf (1.6K views, 45.00 KB)
AT01-CoG-Range.pdf (2K views, 42.00 KB)
