By rosdol - 8/19/2013 7:40:18 PM
Hi, I am trying for day's to create a valid Profile for the A210. Problems:
1) Mogas weight is incorreeclty computed 60l of mogas is computed as 45kg instead of 43, 2 (you use 0,75 instead of 0,73kg/l)!
2) I cannot design a correclty functioning WB/CG Range plot for this machine. I have attached the weighting sheet and the CG Load sheet for you. Can you please come up with a solution ?? I can design the polygon but as soon as I add the empty weight arm it is reddish and off the drawing.
And yes I have read the entry explaining this, but it got not better
Thanks in advance for any solution
Erik
