Aerodrome plate overlay discrepancies
C401
C401
Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)
Posts: 14, Visits: 84
Was wondering if anyone else had noticed any discrepancies with the aerodrome plate overlay and the position of the runway on the skydemon maps when zoomed in?
I noticed this today at Belfast Aldergrove (EGAA-BFS) where I landed on 25, exited on bravo and taxied to the General Aviation Apron. On the SD map when zoomed in it shows a nearly perfect lateral landing on runway 25, and obviously there are no taxiways marked on this. When I overlay the AIP plate, it shows a landing displaced about half-way between r/w 25 and t/w L, and then a taxi through the main apron out onto the car-park.
I understand that GPS is not accurate to the centimetre, but it seems like if the track was shifted south onto runway 25 (like it appears when zoomed in without plate overlay) then it would all-together be more accurate.
I assume there must be an error somewhere as I imagine SD gets the runway position from the AIP which I guess is also used to overlay the plates, so it seems weird for them to show differently.
I add that it is not a problem at this airport, but at larger ones with a more complicated taxi structure I would prefer to have a higher reassurance in the function.
Which plate are you referring to? Is it a Pooley's plate or the one from the national AIP?
C401
C401
Sorry for delayed reply, been working.
It is the one from the national AIP.
It is possible in this case that either the original PDF chart is slightly not to scale, or that our georeference data is slightly out. I will mark the plate for re-georeferencing and that should happen within the next few days, and we'll see if that helps.
C401
C401
Thanks, Tim.
After the re-georeferencing will it be live in the current version or will it require a wait until release of the next version? Just so I know when to keep a look out for it on flights.
It'll be live on the current version. You'll see SkyDemon re-download the plate, which will no longer have the green background, when you open it.
